Something shorting
Old Oct 10, 2001 | 08:43 PM
citgofan99's Avatar
Something shorting
I have recently picked up an 82 Z28 and something is killing the battery. I think it may be the "you left your key in the ignition " warning (it warns when the key is not in the igniton). Please Help.
Old Oct 11, 2001 | 10:09 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
if that chime goes all the time
find the fuse and pull it. then check to see if the battery still has a draw.
if it still does. start pulling fuses till the draw disapears
then trouble shoot that circuit
Old Oct 12, 2001 | 11:10 AM
mtccl's Avatar
When you put the key in the ignition it completes a grounding circuit that activates the "key warning". So, if yours does it without the key in the switch then you have a grounding condition either in the ignition switch itself or somewhere in the warning circuit. Most likely in an 82 the metal fragments from the key wearing down after years of in and out have grounded the ignition switch. I would pull the ignition switch and clean or replace.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Old Oct 16, 2001 | 09:51 PM
citgofan99's Avatar
Thanks for the help. Hooked up fully charged battery and listened. this led me to a relay that was buzzing... took the cover off of it and found the coil was starting to break down and the contacts had burnt together. Removed relay and ordered new one. My Z is now ready to get back on road.
Let the good times roll
Falcon50
Aug 22, 2020 03:26 PM
skinny z
Oct 5, 2015 06:23 PM
