Hatch
Old Oct 9, 2001 | 12:19 AM
89transam's Avatar
Hatch
OK im sure this has been asked a hundred times already. But I did go to previous posts and could not find one that delt with this speficic problem.
OK here it is
When I close the hatch IT catches and starts to pull it down, it makes the noise and starts to pull it down. But, then stops going down and sort of sits there while its saposed to be pulling it down. THe hatch locks, but you can pull it up about 3 inches and you could probobly rip the hatch off if you really wanted too.
I think what is happening is that the thing is latching, but as the motor trys to pull it down, the motor pulls it self up insted of pulling the hatch down.
Anyone had this happen before and how to fix.....
Nate
Old Oct 9, 2001 | 01:23 AM
shotgun's Avatar
Car: 89rs
I know someone that had this kind of problem, I pulled on the motor part and it was coming up. The plastic had cracked and it had gotten free...check that
Old Oct 12, 2001 | 03:54 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The plastic housing and gear nut are available from GM. I've machined drop-in replacement guides from solid nylon (much stronger than the OEM injection molded ones). I have them available for sale as a set of four guides including a new push nut and detailed illustrated instructions.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Oct 17, 2001 | 11:44 AM
89transam's Avatar
How much?
Nate
Old Oct 18, 2001 | 12:36 AM
lonsal's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 89transam:
How much?
Nate
</font>
Housing from GM: $30, Gear nut from GM: $5, Replacement guides from me (aka Top-Down Solutions): $20.
90 RS Convertible
(626)369-0040
Old Oct 18, 2001 | 01:56 PM
89transam's Avatar
Could you email me with ways to pay you casue I have tried to mail you a couple of times.
Nate
Old Oct 20, 2001 | 01:44 AM
lonsal's Avatar
Nate, I sent you e-mail.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
