dimmer wire
Old Sep 19, 2002 | 07:15 PM
fattie92's Avatar
dimmer wire
i need access to a dimmer wire for my new tach. which one off of the dimmer switch can i use? or is there a better spot to tap into? my tach is going in the stock location if it helps at all.
Old Sep 19, 2002 | 09:35 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You could tap into the INST fuse (is powered from the wire comming from the dimmer on the light switch) on the fuse panel or the grey wire at the cluster harness terminal. You could also strip the wire insulation off enough to stick the bare wire into a cluster bulb socket and then plug the light back into it (the bulb socket) and reinstall the socket to the cluster for dimming/lighting power (don't know if that last one made sense to you or not..).
http://92b4crs.tripod.com/86wiring/dia-pics/117-0.jpg
(drag & drop this link into your browser addy bar to view)
That may help you see a little of what I'm talking about.
Old Sep 19, 2002 | 11:18 PM
fattie92's Avatar
can it be ANY light, or does it have to be the ones that go one when you turn your headlights on? i was thinkin bout the light under the dash, but thats only on when you open the door or turn the interior lights on. i was thinking about soldering the wire to one of the bubls on the cluster, but that just doesnt seem to reliable. ill probly just tap into that one gray wire. thanks for the help!
Old Sep 20, 2002 | 12:14 AM
deadbird's Avatar
Engine: TPI 305/ v6
If you're wanting the tach to be able to dim with the dash lights, it will have to be on the same circuit as the dash/HVAC/radio (instrument) lights which is the INST fuse.
The circuit gets it's power from the light switch dimmer itself, is fused at the panel (where it changes from a green to grey wire for some reason) then branches out to the instrument lights. If you put a tap at the fuse, the light in the tach will work as if it's one of the instrument lights.
If you hook the tach up to the orange light on the courtesy (floor and dome) light, it will be on all the time. Switched grounds is what makes the courtesy lights come on.
Old Sep 20, 2002 | 07:52 AM
fattie92's Avatar
ok, got it. thanks alot for yor help!
Ghettobird52
Jul 5, 2024 11:18 PM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
