TPS voltage
Old Sep 22, 2002 | 11:39 AM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
TPS voltage
I tried to check my TPS voltage, I used the blue wire and the ground, with the key off, and I got .52 ohms. Everyone says if I move the throttle it should go up to 4.5 at WOT, but mine goes down pretty fast to 0.0 or just above that at WOT. Am I checking it correctly??? Will I be able to adjust my sensor or should I buy a new one??? I also heard that if the carb bolts are too tight it will make the tps go bad, and each new one will go bad, because the air horn could be bent, and I am notorious for over-tightening bolts. I'm thinking about just buying a new carb, but I'd like to be able to fix this, so any help or suggestions would be greatly appreciated.
Old Sep 23, 2002 | 07:06 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It's volts, not ohms. With the key on probe the center wire of the TPS, that's the wiper and set it to the desired voltage typically about .55 volts or so. You can use the intake plenum or any good chassis connection for the ground side of the voltmeter. I use a paper clip and gently slide it in to the center wire of the connector being careful not to damage the rubber insulator. you adjust it by loosening the mounting screws to get the desired reading. Always check specs for you particular application. According to Chilton if the voltage is below .7 volts adjustment is really not required as the ECM automatically zeros itself at voltages below .7.
Old Sep 23, 2002 | 10:05 AM
SkyWarrior's Avatar
Engine: 305 LG4
Thanks for the help, but I think my TPS is a little harder to get to, since its in the carb and all, but I'll test it like you said and let you know what I find. Sky
Old Sep 23, 2002 | 10:27 AM
SkyWarrior's Avatar
Engine: 305 LG4
OK, I just checked it and I got 4.75v at idle, then I start to move the throttle and it drops to around 1.5v, then it climbs steadily up to 4.5v or so at WOT. So whats the verdict?
Old Sep 24, 2002 | 06:48 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sounds like you have a bad spot on the TPS. If the voltage is bouncing around and you have good connections to it you might consider replacing it. Yeah I realize it's different from a TPS, me thinks it's under a plug of some sort. To set it first set curb idle, then with engine off and key on set it to .4 volts. Replace the plug or locktite the adjustment after it's made.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
