I need quick help..
Old Sep 26, 2002 | 03:14 AM
FataL187's Avatar
I need quick help..
I am an avid camaro fan, however I know very little about cars. Yesterday my turn signals completly stopped working. The hazard lights switch still works fine but nothing when I try to use the turn signal.
About 2 hours before they stopped working they started doing wierd things like flash every 5-10 seconds or really really fast.
I have a repair manual but it doesn't cover this topic at all.
If anybody can help I would greatly appriciate it.
My car details :
1983 Camaro
2.8L V6
Vin : 1G1AP8717DL145305
Old Sep 26, 2002 | 05:21 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If both sides are out most likely it's just a bad flasher. They tend to change flash rate when the bi-metallic strip inside fatigues and fails. If only one side is not flashing then it's most likely a bulb. By the way, welcome to TG. Dan
Old Sep 26, 2002 | 11:53 PM
FataL187's Avatar
Yeah, I was thinking it was a bad flasher but where the heck is it located at? I am hoping I don't have to tear apart the stearing wheel just to get to it.
Thanks,
Jeremy AKA FataL
Old Sep 27, 2002 | 11:04 AM
Morley's Avatar
It is up under the driver side dash. Drop the kick panel and look up there, towards the center of the car is where I found mine.
Old Sep 27, 2002 | 12:17 PM
FataL187's Avatar
I found the little box with the hazzard flasher and the buzzer but there isn't one there for the turn signal. It's getting frustrating!
-Thanks
Old Sep 27, 2002 | 12:27 PM
Morley's Avatar
-Thanks
Mine was tucked up pretty far and was mounted to a small bracket. Heh, keep looking, it is up there.
Old Sep 28, 2002 | 01:43 AM
FataL187's Avatar
THANKS!!!
Thanks, it was mounted clear up on a bracket behind the cigarette lighter. I found it, replaced it and I am turning leagally again... :-)
Thanks for all the help guys!
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
