fuel pump?
Old Nov 29, 2001 | 11:51 AM
fourspeed's Avatar
fuel pump?
several times after i have turned the car off i heard a noise that sounded like the fuel pump was running. it would run for 3-10 seconds and shut off. once i quick turned the key back on and off and the noise stopped. with only 28k on the car i don't see how the ignition switch could be worn out. any ideas
86 IROC 305 TPI, KYB shocks, poly bushings, alochol/water injection, MSD, K&N, map relocated, Flexalite dual fans, 1.6 rollers, March pulleys, ported plenum, overlays, cat gone and 3 inch flowmaster into 2 2.5pipes, MSD 300+ wires and platinum plugs, 170 thermostat, gutted air box and all free mods, (in storage for 15 years)
Old Nov 29, 2001 | 12:59 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There is an oil pressure controlled switch, located on the block, just above the oil filter, which is ORed with the contacts of the ECM controlled fuel pump relay that may be keeping the pump running after the ECM turns the relay off.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
