Hot Spark Plug Wire
Old Oct 3, 2002 | 11:09 AM
ATOVETTE's Avatar
Hot Spark Plug Wire
I'M HAVING A PROBLEM NOBODY SEEMS TO HAVE AN IDEA OF THE CAUSE. MY 305 CARB -86 CAMARO (IT IS EXPERIENCING CARB BACKFIRE) HAS HEADERS WITH THE NUMBER 4 WIRE FISHED THROUGH IT. THIS WIRE AFTER A FEW MINUTES GETS SO HOT YOU CAN'T GRAB IT. ALL OTHERS ARE MILDLY WARM BUT FINE.ANY IDEAS -I'LL TRY THANKS JOE
Old Oct 6, 2002 | 11:07 AM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
I had the same problem. I ended up having my headers ceramic coated/ran a custom length wire set from the distributor->around the back end of the head and under the headers/used Taylors boot protectors on the boots as well. When I wrote to Super Chevy they said ACCEL sells a steel braided/shieided wire set that would also correct this problem.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
