Fuel Pump Relay?
Old Oct 5, 2002 | 08:57 AM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Fuel Pump Relay?
Can someone please tell me where the fuel pump relay is located? I thought I could just pick one up at the auto parts store and match it up but there are a couple that look the same. Thanks
Old Oct 5, 2002 | 09:19 AM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
the fuel pump relay is on the firewall. its on the drivers side up near the windsheild its just to the right of the brake booster. there sh0ould be two there the one on the right would be the cooling fan one , that is if yours has an electric fan, and the one on the left is the fuel pump one.
Old Oct 5, 2002 | 07:26 PM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Thanks!
Old Oct 5, 2002 | 09:18 PM
meridius's Avatar
no problem but a little trick I do is to see if thats the problem before buying it I swtch the cooling fan one with the fuel pump one because they are the exact same part
Old Oct 5, 2002 | 09:32 PM
Andy Bush's Avatar
Hi
One difference is the number of terminals in the relay, so that is a guide, you have to take the relay off to look inside and count the terminals but that is easy.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
