Adding power windows
Old Dec 11, 2001 | 11:54 PM
rlax31's Avatar
The camaro I'm thinking of buying does not have power windows (or mirrors for that matter). I was wondering how hard would it be to put power windows into it. I was thinking find doors from a junkyard with the same color as the car, then get a console piece that has the buttons. How hard would the wiring be? Is this just a stupid idea? Should I deal with the windows as they are.
Old Dec 12, 2001 | 03:08 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I add power windows to my car.
If you do add power windows you might as well add the power locks too..
You might want to check out technical articles - Power Windows 101
Good Luck.
90 Firebird SSA (Bone stock 3.1) With 14 Miles on it
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar, Jegster sub-frames
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Dec 12, 2001 | 04:30 PM
rlax31's Avatar
So the wiring wouldn't be that hard? Would I just have to run wire(s) from the motors in the door to the switches in the console? Do I need a relay of somekind?
Old Dec 13, 2001 | 08:52 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Wiring was not that hard. No relay. But you also need a power source. I used the fuse box for power.
Old Dec 14, 2001 | 02:12 AM
Fade00's Avatar
I'm also going to be adding power windows/locks to my car. I had to goto GM to get some wiring diagrams though, it was free. I couldn't find anything for wiring on the net.
No relay for the windows, but you need one for the locks.
Old Dec 14, 2001 | 02:58 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This is for an 85 camaro...
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
... all years of both models are pretty much similar.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"I don't know the key to success, but the key to failure is to try to please everyone."
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
