TPS Voltage Check....
Old Oct 6, 2002 | 10:42 PM
bigjeepinyj's Avatar
I just got finished putting on my TPI and was wanting to check the TPS Voltage. Where do I stick my jumpers in to? I read the writeup on here but dont know if I am going it right. A picture would be great...... Is there anything else that I should check the volts on also? Thanks alot.
Old Oct 7, 2002 | 04:12 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
TPS has three connections. The center one is the wiper and that is the one you put the positive probe into(I use a paper clip folded out to go through the rubber insulator). The ground lead of the meter can go to any GOOD chassis ground then simply adjust it for .5 volts.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
