Coil Arcing
Old Oct 16, 2002 | 09:38 AM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Coil Arcing
Can anyone tell me why my coil would be arcing into itself? Wires, cap, rotor, plugs and coil are all new. have swapped out several coils and the all did the same thing. It arcs from center out the bottom of the boot (not through the boot) into the metal that runs around the coil itself.
Any ideas would be appreciated.
Old Oct 16, 2002 | 06:24 PM
AFRO IROC Z's Avatar
try using some dielectric grease that usually helps.
Old Oct 20, 2002 | 07:25 PM
J Kylez's Avatar
I had a small crack in the plastic around the coil once and had this problem. I tie wrapped some rubber insulation to anything it could arc to. This fixed my problem without replacing the coil.
Just my 2 cents.....
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
