FIRE - now i got more problems
Old Oct 16, 2002 | 08:46 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
It all started when I smashed some wires under my passenger side valve cover in the back. This caused a fire and and oil to splash on the headers which caused smoke. I pulled the valve cover and about 10-15 wires were affected by the fire. I thought pretty much all of the wires on the passenger side heading towards the fender went to the computer and since I have a carb and HEI I figured they were not important. I defineatly knew they didn't go to the starter or distributor or alternator. All of the wires were very small like 14 awg or smaller. All of them had the rubber insulation burned off of them many up to 8" of bare wire. So I just cut the wires off where they were bare metal. Please remember that most of these wires went from the back of the passenger side valve cover and turned towards the front of the car. Now I went to test everything and everything is fine, except for the gauges. ALL of my gauges are dead, none work. What did I do? Do I need to fix one wire to fix all of the gauges or do I need to solder a bunch of wires to fix the gauges? What did I do?
Thank you,
Brady
Old Oct 16, 2002 | 09:47 PM
also just saying there is no power to the gauge cluster. no lights work or anything
Old Oct 16, 2002 | 09:52 PM
ok i posted thinking "no way the gauges dont work because of the fuse it has to bne cuz i cut wires"
well i was wrong - i blew the 10 amp fuse replaced it and all is good.
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
