Swaping Guage Clusters??
Old Oct 30, 2002 | 05:49 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
I WANTED TO KNOW IF I SWAP MY TRANS AM GUAGE CLUSTER WITH A 140 K/M SPEDO , FOR ONE OUT OF A GTA THAT HAD A 220 K/M SPEDO, WOULD IT WORK?, AND IF IT WOULD, WOULD IT BE OUT OF CALABRATION? WHAT DO I HAVE TO DO?
Old Oct 31, 2002 | 01:40 PM
turtle's Avatar
you can swap them fine just be sure its mechanical for mechanical or electronic for electronic. simply meaning what is giving the speedo its info either a trans driven cable or a sensor pickup.
but yes you can swap them and it will work fine. the speedo gears in the trans actually set the speed on the speedo. so if you change rear gears you have to change speedo gears in the trans otherwise it will read wrong.
sheachopper
Jul 31, 2019 11:27 AM
