Question about when trunk mounting battery...
Old Nov 7, 2002 | 05:47 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
When you mount the battery in the trunk area. Do you have to buy a distribution block or osmething for the front? To connect the battery to everything else. For the people that did this mounting what did you do? If you have any pictures it would help alot to. Thanks.
Old Nov 11, 2002 | 10:01 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
Check your current (no pun intended) factory wiring from the battery. You should be able to use the hot lead on the starter as a distribution point.
I moved my battery to the hatch and I've run it to the starter where the fusible links feed from.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
redmaroz
Aug 16, 2015 11:40 PM
