Head light problem on 92 firebird. How do you...
Old Nov 20, 2002 | 04:40 PM
DAHULK2000's Avatar
One of my lights was up for a long time, and i thought the little motor had given up. Well, all of a sudden last week it went down! I can't figure that out? Well, now it stayed down and it doesn't wanta go up. Is there a way to pick it up manually for when i drive at night? By the way, its the passenger's side head light. Thanx for any info.
Old Nov 21, 2002 | 09:41 PM
Vader's Avatar
If you raise the hood, you should be able to see a knurled **** on top of each headlight motor. The **** has markings to indicate the direction to turn to manually raise or lower the headlight.
Old Nov 21, 2002 | 10:18 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Head light problem on 92 firebird. How do you...
Also do a search for Top Down Solutions www.top-downsolutions.com
He has repair kits to fix those things.
Old Nov 22, 2002 | 06:35 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes. I manufacture two versions of the kit to repair your headlights. One includes the side cover and motor housing gaskets. Both are shown on my web site. Boith kits have 3 precision machined Delrin bushings that replace the OEM gel inserts that have gone bad on yours. The kit insludes detailed instructions and new zinc palted washer-head screws and nuts (the ones mounting the motor cover often snap the head on removal).
There is still a slight glitch on the site that prevents you from being able to register or purchase online. Until I've got it fixed, just e-mail me with your shopping list.
Thanks,
Lon Salgren
Top-Down Solutions
TDS web site
TheJoeY88
Dec 31, 2016 07:30 PM
justin57
Aug 20, 2015 07:05 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
