Wiper troubles!
Old Nov 26, 2002 | 02:38 AM
DonCamaro's Avatar
Wiper troubles!
I have an 84 berlinetta with malfunctioning wipers. When I press the "wiper" button, they work normally, then they start to slow down and stop. The wipers ussually work for 2 minutes before stopping. Once they have stopped, I can't get them started again! I have to let the car sit for a long time before they will work again. Anybody know what is wrong? Thanks.
Old Nov 26, 2002 | 09:17 AM
88fbird's Avatar
Car: 84 S-10:(
I had the same problem. I replaced the wiper motor. The problem hasn't been back since.
Old Nov 26, 2002 | 10:32 AM
DonCamaro's Avatar
Thanks. I thought it had to be more complicated then replacing the motor.
Old Nov 26, 2002 | 11:34 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
nope motor is shot, gets overheated and quits working. most likely cause.
Old Nov 26, 2002 | 02:45 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
same as mine. Change the motor.
Old Nov 27, 2002 | 02:07 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Be Advised ----->
The Camaro Berlinetta wiper motor is NOT the same as any "regular" camaro wiper motor !
You can probably retro-fit a "regular" camaro motor onto your car - but if you try this be sure that you get the Electrical plug along with the replacement wiper motor when you buy it !!!
Good Luck finding one !!
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
mrbird
Oct 20, 2015 03:43 AM
Hal87
Sep 26, 2015 09:26 PM
Lmancha96
Sep 25, 2015 08:11 PM
adelane
Sep 9, 2015 08:51 PM
