Neutral safety switch wiring
Old Dec 15, 2002 | 11:20 AM
Fastmax's Avatar
Car: 89 IROC
Engine: 350 CI Tuned Port
Transmission: Automatic
Axle/Gears: 3:45
I am in the process of changing my car over from a manual to an automatic. In the manual the car uses the switch on the firewall connected to a heavy purple and a heavy yellow wire around 10 gauge or so. The switch on the side of the auto shifter doesnt appear up to the task of whatever amps are pushing thru this 10 or so gauge wire.
Are appearances decieving? Do automatic cars also run 10 gauge wire thru the little switch or do I need to set up some sort of a relay system?
Roy
Old Dec 15, 2002 | 01:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Neutral safety switch wiring
Yes they are. Think of the current the flows through the tiny element in a fuse. Also, the neutral switch only has to carry the load untill the car is started. In my buds truck, since we don't have a shifter for it yet, I just use a 4" 20ga jumper wire across the harness plug to start it.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
