temp gauge going crazy
Old Dec 21, 2002 | 11:51 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
whats most likely gone bad when my temp gauge occasionally shoots to a higher temperature for a minute, then back down to the real temp? The car is a stock 84 t/a, l69 700r4, thanx
Old Dec 23, 2002 | 12:23 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
When does it do this? When you driving or when you just siting?If it does it when your driving I would probably say the wire going to the sensor probably has a opening in the insalation and is touching a ground when the car vibrates.
Old Dec 23, 2002 | 02:09 AM
Egglick's Avatar
Or if your antifreeze is really low, you could be getting super hot air bubbles that would do that. Check the coolant level.
Old Dec 24, 2002 | 09:33 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If it's a fast swing look at the sender located between and above cyls 1&3. It has a single green wire, sometimes it gets burned and will momentarily short to ground causing the guage to peg. If it's a slower change troubleshoot the cooling system.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
