Power doors on a non-power car
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, I have a post about how to put power mirrors on a car without them, but I found a pair of mint doors, with power windows and locks. There is no wiring harness available, so I was wondering... do I just put the power windows thru a switch and a fuse to the battery? Same with the power locks, is there any hope here?
Car: 91 Maro & 97 Ram & 05 Roadstar
First make sure to get the little black boot between the door and the car door frame or get the "Jam Tac??" that Jegs has.
It would also help to get ahaynes or chilton manual. There is allready a fuse in the block that you wire up to. The rest it just to the switch and window! Let me know how it goes I'm still looking for a set of switches.
you can make your own window harness if you get the connectors for the window motor and the switches. more details are avaliable here:
http://www.p71interceptor.com/thirdgen/powerwindows
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
