can someone help???
Old Jan 6, 2003 | 10:38 AM
mike906's Avatar
can someone help???
I have a 91 z28, the fuel pump was bad so I changed it this weekend. Now the car is hard to start and hesitates. But it will idle just fine. Need help really bad, any sugestions??
Old Jan 6, 2003 | 11:09 AM
89rsIMPRTETR's Avatar
you did replace the fuel filter right? if not do it, other wise just do a basic checkup, plugs wires distributer and timing replace those parts that are bad
Old Jan 15, 2003 | 12:28 AM
evelkneivel001's Avatar
Car: 87 GTA
Engine: 383 Stroker
Transmission: 700 R4
try fuel pressure too.
It is always good practice to check fuel pressure after any compoent relating to the fuel system has been altered. Hope that helps!
