Dropping Voltage
Old Jan 7, 2003 | 03:21 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Dropping Voltage
Whenever I press the brakes my voltage drops from about 13-14 to about 9-10... why is this? Also, whenever i turn on my rear defroster, it will dip to this low range.... this has caused me a lot of problems, because with this low voltage, my blinkers blink slower, causing a lot of near misses.
Old Jan 7, 2003 | 05:22 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It may be a fusible link @ the starter - there are three of them attached to the large lug on the starter. Check the voltage under load there & then @ some points down the line (@ fuse box) to determine where the voltage drop is occuring. The brake lights & turn signals are powered by the stop / hazard fuse, which is powered from one of the fusible link feeds.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
