Bad Alternator?
Old Jan 27, 2003 | 01:05 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Bad Alternator?
My buddies voltage guage is going up and down and its all stock so he went and replaced it and it still does the same thing. He measured the voltage on it and it puts out between 11.5-14 volts and it alternates. Never did this before I guess so what do u guys think?
Old Jan 27, 2003 | 04:25 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
On the 2-wire plug there is a red wire going to the starter. Check the fusible link on this wire.
Old Jan 27, 2003 | 06:23 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Have you checked the alternator with a standard multimeter across the battery terminals? Test it with one at idle, revving, and with some electrics on too...once you've checked the fusible link mentioned in Mikes86SC's message, and if you can eliminate it as a problem, the alternator should not drop below 13.5 volts. If it does, it's pretty safe to assume either the alternator or drive belt are at fault.
Si
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
