power windows
Old Feb 7, 2003 | 07:50 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
power windows
I have a 91 rs and my passenger window stops when going up. It will go up some and then stop again. Then I wait a minute and it will move up just a little more. Is it just a bad connection? How do I fix it?
Old Feb 8, 2003 | 12:00 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You probably need to get inside the door and grease the window tracks. IIRC the windows work on a thermal circuit breaker. If the motor is struggling to raise the window itwill cause extra strain on the motor/ heat in the circuit. This causes the breaker to trip & then reset after is cools (doesn't take long, similar to how a turn signal flasher works really I guess). The other possible problem could be the motor is dieing and causing the same fault. Don't quote me on any of that because I'm not 100% sure about the breaker.
Old Feb 8, 2003 | 07:38 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most likely the motor brushes are worn. When they get low the get very loose in the brush holder causing erratic operation. The thermal breaker is a simple bi-mettalic strip that warps under extreme current opening a contact and removing voltage from the motor. Even if the tracks are dry as DB says, generally the motor will labor for a bit before the it thermally cut's out. Chances are upon inspecting it you will find it's simply the brushes.
Old Feb 8, 2003 | 01:10 PM
MdFormula350's Avatar
yup the same thing happened to me, the brushes in the motor were shot the heck!! so i bought a new motor and all is well....
Old Feb 9, 2003 | 05:12 PM
91tirespin's Avatar
Car: 91 camaro rs
Engine: 355
Thanks a lot guys. Could I get the motor from a local auto parts store? Is it fairly cheap and should it be pretty easy to install?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
