Coil wires
Old Feb 24, 2003 | 04:52 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Coil wires
Ok, this is a dumb question but I lost two wires. I have an 87 TPI motor and while I was putting the MSD on I lost two of the coil wires. I hooked up to the big pink and the skinny pink but I can't find the other two or the connector that is supposed to go to the coil. I swear they are not behind the engine or distributor or anywhere else but they have to be somewhere. Where do these two wires connect? Any sugestions? I know stupid
Thanks,
Tyler
Old Feb 24, 2003 | 11:35 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
On my 88 the big pink and white goes to the wire harness next to intake which runs to throttle body etc. The small pink and another white wire goes to distributor.
Old Feb 25, 2003 | 11:40 AM
HotRod's Avatar
Car: 87 GTA
There is a small pink and white coming out of the distributor but they are pluged into a connector and don't have anywhere to hook up to. Does your small white and pink come straight from your dist. to your coil with no other connections? Does anyone have the wiring schmatics for an 87 TPI GTA? The ones in the tech pages stop at 86. Thanks for the help,
Tyler
Old Feb 25, 2003 | 08:40 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
Yes the small white and pink come straight from my dist. to my coil with no other connections. The large pink and white runs from the other side of the coil to the large wire harness that runs from behind the motor to the front of the motor on top between valve cover and intake.
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
L98GTA87
Aug 5, 2015 11:02 PM
