electric fuel pump
electric fuel pump
anyone here know how to check electric fuel pump mounted in the gas tank for electrical problems? wiring, sensors, plugs, fuses etc...? any info and/or wiring diagrams would be appreciated. I have an 87 Z-28 305 TPI, I replaced the pump a few years ago and haven't put too many miles on the car since. it was running fine and one day just wouldn't fire up and I didn't hear the pump come on so I'm thinking it's electrical
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
there are 2 pins on the aldl you need to jump together, nut i dont remember what the are. if you search on the tpi board it should tell you, or a haynes manual will have it.
thanks
anthony
thanks
anthony
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Your '87 should be similar to my former '85 Z28. There is an inline fuse in the fuel pump power wire. On my car it was located on the other side of the body behind the rear seats (trace the wire under the carpet through a hole behind the seats). Can't remember if it was accessable from inside the car or not. I think I was able to pull the fuse and fuse holder through the hole in the body. Unfortunately, I ended up having to replace the pump.
Originally posted by timtpi305
deadbird was right apply 12v to terminal g the fuel pump will turn on unless the pump is bad
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by RSFreak
Doesn't turning the key to the 'on' position have the same effect?
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
