vats system (anti theft system)
Old Mar 11, 2003 | 09:01 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i think found out whay my speedo doesn work. its because my vats system isnt sending any juice to my pcm .does any one know how to disable the vats ?
Old Mar 12, 2003 | 07:07 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If the car runs it isn't the VATS. The VATS does not control voltage to anything other than the starter enable relay which feeds the starter solenoid. It should not affect anything to do with the speedometer or VSS circuit.
Old Mar 12, 2003 | 05:09 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
sorry... i never mentioned that the car had a 350 in it. it used to be a 3.1 but i put a carbueted 350 in it. that would explain why it runs but i still cant figure out why my speedo doesnt work.i was told the vats shuts off the pcm. does it?
Old Mar 13, 2003 | 05:13 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Vats does 2 things. It will not let the engine crank, and it will not allow the ECM to pulse the fuel injectors. What year?
Old Mar 13, 2003 | 12:15 PM
J's25thZ28!'s Avatar
danno i think im having a problem with my VATS...I shot you an e-mail with more in depth info on it. I appreciate your help.:hail:
Old Mar 13, 2003 | 11:19 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok thanks guy i got it fixed. the computer chip was bad. i got a new one from a junk yard and all my gauges work now.
thanks anyway
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92projectcamaro
Jan 18, 2016 08:00 AM
Stryker412
Sep 20, 2015 06:59 PM
Winchester1094
Sep 15, 2015 09:48 AM
studebaker60
Sep 7, 2015 12:36 PM
