Wiring problems/dead ignition
Old Mar 18, 2003 | 11:42 PM
cesov's Avatar
91 Camaro changed from TBI 305 to a carb 355. Have starteer wired in to heavey purple wire from drivers side harness then to battery. Ignition will turn but will not crank the engine. HAve all other wires from passenger cluster and driver's cluster cut except for all red fusible links, the green temp sender, the tan and white oil sending unit sensor, the white tach wire and I believe the two tranny sensors which are not hooked up.
I can jump the starter with a screw driver but not turn the key. Is it the chip sensor or another problem Any ideas???
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
Bryan F
Aug 18, 2015 02:28 PM
