Wiring Diagram
Subscribe
Mar 22, 2003 | 11:32 PM
I have an 82 Camaro that was gutted. I have installed the dash and wiring harness from an 84 Camaro Berlinetta. But I an i need of a wiring diagram for the 84. Or i aleast need to know what combo of wires run the Speedo, Temp, and Oil Pressure gauges. I was told they worked before removing them from the donor car but they do not work now. If anyone could tell where to find a GOOD wiring diagram that would help me alot. Thank You
Reply 0
Mar 24, 2003 | 11:42 PM
An Analog to digital conversion - How fun !!! I actually converted a Berlinetta in the reverse one time, From an 85 Digital set-up to an 86 Z28 Analog interior..... That project took awhile !
If you need the wiring diagrams than contact my buddy Mike - he can hook you up with a CD containing ALL the berlinetta wiring diagrams.......
The Digital Camaro Wiring Diagrams ----------->
PS........ The Digital Berlinetta has an Electric Speedo Sending unit and you will need to replace the Cable driven sending unit in the 82. The wiring for the gauge sending units is pretty straight forward - perhaps the wiring is not matched correctly at the firewall connector. ( those sensor wires matched at the firewall during my swap - but I am not sure about the 82 Camaro engine harness and the wiring may not "match" at the firewall ! )
Reply 0
Mar 25, 2003 | 01:41 PM
Thank you. I've been into contact with mike and he also gave me you email and web address. I will be incontact with you. Thanks.
Reply 0
Subscribe
