Fog Lights
Old Mar 31, 2003 | 04:35 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Fog Lights
I have this strange problem with my driver side fog light and side marker.
Well, they don't work . Both of them don't work which is what is strange. They are attached through the same cable. Could this be a fuse? Would a fuse just be for the driver side fog light and side marker? Or could it be something else. The next thing that is attached to those cables is the driver side front turn signal, and it works fine.
Any ideas?
Oh, and by the way, this is for an 86 Trans Am.
Old Mar 31, 2003 | 08:33 PM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
well if they are running in a series like you said, you might have a burnt bulb which isn't completing the circuit thus making your lights not work.
Old Mar 31, 2003 | 09:08 PM
patrickm00's Avatar
the fog's shouldn't be in series since you can turn them off separately. you've got a bad wire.
the lights don't have separate fuses for each side.
Old Mar 31, 2003 | 09:09 PM
patrickm00's Avatar
or i guess you could just have a dead marker bulb and a dead fog light bulb...
Old Mar 31, 2003 | 10:33 PM
Sonar_un's Avatar
Car: '86 T/A
I should take a pic. but it looks to me like its attached in a series. I don't know, all I know it looks like a bitch to replace.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
