fog lights
Old Apr 29, 2003 | 12:08 PM
Camaro90RS43's Avatar
fog lights
When i purchased my car the fog lights weren't working, i'm guessing it's not connected, does anyone know where i can find the wiring for the fog lights? Thanks.
Old Apr 30, 2003 | 08:41 PM
txhotRS's Avatar
maybe your best bet for STOCK wiring would be a junkyard... but if you know a little about electricity (and wiring) you could jerry-rig it and It should work fine... (i rigged by brights, they didn't work when I bought the car, and I rigged my fog-lights, becasue then were after-market BUT they didn't work when I bought the car either)..
Old May 1, 2003 | 08:32 PM
SilverSub122's Avatar
wiring the fog lights isnt hard at all, the hard part is tracking down which wires go to what. if you dont want the stock lights you can get a kit from your local kragen or autozone or whatever for like $70. it took like 15 min for me to install by myself, if you need the wiring diagram search for it, there have been posts with the diagram on it, if i had a link id give it to ya. good luck, wiring can be about as annoying as fixing leaks
Old May 1, 2003 | 08:42 PM
txhotRS's Avatar
$ 70 ... WTF... I paid $25 for mine from autozone... they are 55w halogen rectangle lights (stock Z-28 size)... AND THEY ARE WHITE, instead of that yellow crap... took 30 minutes.. only because I installed the switch in my ash-tray... along with my kill-switch, and my electronic cut-out switch...
good luck
Old May 1, 2003 | 09:14 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
25 dollars for "stock" replacement fog lights? one of mine has broken glass but both still work. my fog light switch on the other hand wont keep the lights lit unless i hold it down. so $25 for both?
Old May 1, 2003 | 10:31 PM
well i have no idea what the wattage of my lights are but they are freakin bright. they are the roughly the same color as my 'cool blue' headlights which is why i bought them. but yours came with a complete mounting kit and wiring harness w/ switch for $25??? i had to get all the wiring and all that because my RS didnt have fog lights stock i just figured thats why they cost so much, but evidently i may have been bamboozled.
Old Jul 16, 2004 | 10:39 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I paid 15$ for the small oval fog lites I put on mine. Came with switch and wiring. Bought them from wal mart. It was way cheaper than just a lens for my stock one. I just spliced into the wires from my old ones.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
