carb to fi
Old May 3, 2003 | 01:09 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
carb to fi
if i go from my 84z l69 ho 5 spd what kind of wiring job would i have to do to go to a lt1 or ls1 all help is appreciated thanks
Old May 5, 2003 | 09:16 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
You'll need the harness and computer. The computer would have to be programmed without the 4l60E programming. Or you would have to use a 4l60E. I'm not sure how the guages would work though. If the speedo is cable driven, that should be fine then. New engine mounts would be needed, if you use a 4l60E then a new trans. crossmember would be needed also.
Matt
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
