possessed door locks??
Old May 9, 2003 | 11:44 PM
hitthethrottle's Avatar
my door locks just keep locking and unlocking themselves while im driving or parked. Anyone have any clue whats going on? I have a aftermarket alarm system that was installed about 1 1/2 years ago with keyless entry but i dont think it has anything to do with that. Any help is appreciated
Old May 10, 2003 | 04:18 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
What year is the car??? I have an 86 IROC that had that problem about a year after i bought it. You might wanna check out the actual switches to the locks. Mine were worn down so bad that any light touch, bump or anything would just set em off. I replaced em with new ones and no problems since. Hope this helps.
Old May 11, 2003 | 06:21 PM
0103837's Avatar
Car: Camaro
Engine: Gas
Transmission: Automatic
Yeah, I've had that problem too. Turned out it occured when the lock cylinder on the door wasn't totally up right. When the cylinder is worn you can pull the key out in almost every angle... Check that your cylinder keyhole is TOTALLY vertical. That should cure the problem. Tell me how it turned out...
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
