speedo question
Old May 23, 2003 | 06:37 PM
gigas's Avatar
speedo question
I got a little problem here...i installed a 145 cluster about a week ago (84 z28)and my speedo just went off on me..odometer and trip odometer wont even work eigther..it could be the speedo went bad?? If so..can i remove the 145 speedo and install my 85 speedo till i find another 145 or i cant??
Old May 23, 2003 | 07:28 PM
1986redbird's Avatar
since it's an 84 unit it has a mechanical speedo, I would check the cable comming from the tranny, it's possible it either came out of the tranny or speedo or it broke (not un-heard of), you may also have a stripped gear set where the cable goes into the tranny.
try disconnecting the cable from the back of the speedo and driving the car while having someone watch the end of the cable and see if it is spinning, if so then it may be the speedo, if not then check the rest of the cable.
Old May 23, 2003 | 08:57 PM
gigas's Avatar
Well,i did like you told me and exactly,the cable is not spinning so i guess is not the speedo...also i tried to pull that innercable (slowly) and its comming off the cable so i guess is broke somewhere....so i guess i will have to get me another cable.Well i really thank you for your help man..take care
Old May 23, 2003 | 09:47 PM
the inner cable will come out of the casing even if it's not broken, I would jack the car up and disconnect the cable from the tranny and try spinning it from that end while watching the other end and see if it's moving, if not then it's definetly the cable if it is then it may be the speedo gears in the tranny, don't worry, they're not hard to change or expensive for that fact.
Old May 25, 2003 | 12:04 AM
gigas's Avatar
Well..i took it off tranny and it was broke right there...just went to the part house and got me a new one for $15 and is already on and spinning...thanks a lot man.
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
