Headlight problem...
Old May 25, 2003 | 09:25 AM
Meat Curtains's Avatar
Hey guys. I'm having problems with my headlights on my '84 bird. I'm getting power to the headlight motors, when I hit the switch the headlights both come up like normal. But... No light. For some reason I'm not getting power to the headlights themselves (confirmed this with a test light on the headlight connectors). Any idea where I should start to fix this? All fuses and relays are good, could this be a switch? Ground problem somewhere?
Old May 25, 2003 | 04:29 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Possible ground. You might also want to check your relays. There is a headlight relay somewhere in the area of the headlights.
Old May 25, 2003 | 06:41 PM
Wasn't aware of one near the headlights... Any idea where this would be?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
