Fuel pump relay
Old Jun 10, 2003 | 03:27 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Fuel pump relay
Hmm. I thought that if you disco'd the fuel pump relay...
the car shouldn't start... I'm trying to find a non-invasive spot to put a cutoff switch
Old Jun 11, 2003 | 06:22 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Fuel pump gets power from 2 places, the relay and the oil sender. The pump will prime when the key is first turned on to bring up pressure then it shuts off and after the engine starts re-energizes and feeds power to the pump. Also, after 4 psi oil pressure is reached a switch in the oil sender feeds 12 volts in parallel with the relay to also run the pump. Thats why when the relay goes bad you have to crank the engine several times to start. The starter turns the engine and develops the 4 psi. You will need to find the wire that feeds the pump in the chassis AFTER the parallel circuit and use it for a fuel cutoff.
Old Jun 11, 2003 | 03:16 PM
waltersb's Avatar
ok, the oil sender being the oil pump?
it's not something (with the term sender) to be in any of the manuals I've read..
thanks for the info, just made my life a whole lot easier..
any idea what gauge that wire is?
I bought 14 and 16... hopefully 1 of them is right
Old Jun 12, 2003 | 05:40 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Sender is the unit that feeds the oil guage, not the pump. It is a dual function sender, i.e. it runs the oil pressure guage as well as having a switch that closes at 4 psi to run the pump in conjunction with the pump relay.
Old Jun 12, 2003 | 04:49 PM
waltersb's Avatar
now I just have to figure out which unit is the oil sender and where those wires go...
Looks like it comes right out of the harness
and I didn't see it anywhere on the wiring diagram
Old Jun 14, 2003 | 02:58 PM
waltersb's Avatar
I've looked at the manual, and at the engine, but damned if I could figure out on the engine which is the oil sender...
Looks like it's at the back of the engine, on the left hand side (if you are facing forward) but i can't find anything.
Next question, the wiring for the fuel pump, does it go along the transmission hump? I found a set of wires that goes through the body right between the rear passenger seats.
Old Jun 15, 2003 | 07:05 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Look for a tan/wht wire, thats the 12 volt feed to the pump. Putting a cutoff there should disable the fuel pump.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
