Fuel pump relay question.
Old Jun 18, 2003 | 12:47 PM
firebirdkid's Avatar
I ran the codes and came up with an MAF code and a fuel pump relay code. I figure I'd replace the relay first. I removed the relay, cleaned it up a little, and replaced it. The code still showed up. So of to Autozone I went to get one. 10 bucks. Cool. I got to replace the old ome and notice that on the old relay and plug, there are only 4 connectors. Both the relay and the "outlet?" on the wiring harness side have only 4 prongs, but look like they should have 5. Example" - - - o - (the "o" meaning there is no prong there).
The new relay looks like this - - - - -
Now is it that I am missing a **** on the old relay AND the corresponding reciever on the wiring harness where it plugs in, or is it supposed to be like this and aytozone sold me a universal relay for most GM cars? Thank you.
Old Jun 20, 2003 | 12:44 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There should only be 4 (5 technically, but 2 are on the same prong/terminal.. FP power and the test wire leading to the ALDL plug in the car) on the harness plug. The relay is probably revised and/or universal
Old Jun 21, 2003 | 11:39 PM
Adam87iroc's Avatar
Did this solve any of your probs? I'm about to replace the relay myself.
Old Jun 22, 2003 | 11:11 AM
3gc's Avatar
3gc
Car: Z28
Did you clear the codes after you cleaned up the relay and plugged it back in?
Old Jun 23, 2003 | 03:50 PM
It cleared the code, but I still have an MAF code to deal with.
Old Jun 23, 2003 | 08:53 PM
3gc's Avatar
3gc
Car: Z28
What kind of MAF code? Code 33?
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
