No start/90 IROC
Old Jul 5, 2003 | 06:20 PM
Project86Iroc's Avatar
No start/90 IROC
I have a 90 IROC, 305 TPI. The motor cranks, I have plenty of spark, fuel pressure is good, but the injectors are not firing. Does this sound like a VATS related problem? The security bulb was removed by Yaksass Used Cars, so I cant diagnose that way
thanks fellas
Mike
Old Jul 5, 2003 | 08:54 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Check to see if injector fuses are blown, there should be 2 different fuses one for each bank of injectors. hope that helps. I believe that VATS Kills spark, so i dont think it is that.
Old Jul 8, 2003 | 11:18 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
You may also want to check your fuel pump as well. It could be a fuse or the fuel pump it self--not providing fuel to the fuel rail.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
