alright all you ppl with a mysterious batt drain....check this out.
Old Jul 29, 2003 | 01:54 PM
camaro 670087's Avatar
im not trying to sound proffessional or anything like that and im not saying that this is the sollution to all your draining problems but i just found out what was wrong with my batt drain....
ive posted my problem in detail many times and i never got this "idea" to come by me, so now that i figured out my problem i guess ill tell you guys what was wrong and maybe you have the same problem.
so i was outside in my car (like always) and i noticed i had a few blown fuses (3) of which i only know that one of them was for my stereo and the others i do not know cause my fuse box is so worn. but anyways, there was this one somewhat loose fuse that was also blown and i changed it and using another fuse of the same amperage i ripped out the little metal prongs and attached them toi the new fuse i was going to put in. now that fuse is nice and tight. and amazingly when i charged my batt for the millionth time, my volt meter shot up to 14 volts and the car is now running beatifully (electronic wise) i have some other wierd noise coming from under the engine which i will be posting in another post.
but hey check ur fuses as that may be your problem
Old Jul 30, 2003 | 05:08 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Not unusual. Probably the fuse that feed the alt sense line. You did not have a drain so much as you had a no or low charge condition. The alt "sense" wire feeds from a fuse generally marked "fan/chg" in the fuse panel. Good detective work.
RedLeader289
May 28, 2019 01:47 PM
mattcanty
Oct 12, 2015 11:08 AM
Gordonr1973
Sep 29, 2015 11:59 AM
mfp189
Sep 27, 2015 09:25 AM
Kingchevy
Carburetors
Sep 17, 2015 12:09 PM
