Fuses in an ´89 IROC
I´m trying to locate the fuses for my parking lights and ignition, Im about to install a buzzer that will sound if I have the engine running and not having the lights on, and if the lights are on and the engine is not
Sofar I´ve got that the ECM IGN is the fuse for the ignition, but I can´t find a fuse for the parking lights. The Haynes manual didn´t tell me much, so I´m starting to believe there ain´t no fuse for the p-lights.
If not, which relay controls that light?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
1989 IROC Fuse Panel
This is as per CHILTON (From left to Right.... starting from the top with the ECM Fuse and amps).
ECM Ign (10) Clster (N/U) Crank (3) C/H Fan (20)
Turn B/U (20) INJ (10) Tail (20) HTR - A/C (25)
Gages (10) F/P Inj 2 (10) Ctsy (20)
Inst Lps (5) Radio (10)
****** Wpr (25)
(There's a section on the bottom left where I placed a couple of stars.... where the manual indicates this to be an ignition area. You could probably splice into it using the proper termial, as the ignition clearly starts the car with the ECM Ign fuse (top left) removed)....
****** Wpr (25)
You're best bet for the P/Lights
Just trace them back to the fuse box. GM is notorious for using Fusible Links, and this is your best bet in finding where they lead....
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Aug 11, 2015 03:17 PM
