flashers, blinkers?
Old Aug 13, 2003 | 07:48 PM
svideo925's Avatar
flashers, blinkers?
okay, first things first. when i turn my headlights on my 84z28 the blinkers stay solid. they work fine when headlights are off. i replaced all the bulbs. no fix. i opened up the convience center but i only have one flasher. my hazards work fine all the time. if i remove the flasher the hazards stop, so i assume that it is the hazards flasher. but the horrible thing is, in the convience center there is another set of slits for prongs, you would think this is for the blinkers flasher, but no wires go there. i have a large grid of cables with nothing conected in the center as well. so my question is, is there another spot where this flasher for the blinkers could be. or can i run new wires for the flasher. i would like to fix the problem.
thanks so much
stephen
Fronzizzle
Feb 9, 2017 09:31 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
TransAm87
Sep 14, 2001 04:34 PM
MTCAMARO
Mar 24, 2001 04:44 PM
