Headlights and interior lights dim in an out
Old Aug 14, 2003 | 09:21 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I have an 86 T/A and everytime I turn the parking or headlights on, the headlights keep dimming in an out and so do the interior lights under the gauges. Whats wrong? How do I go about fixing this problem? Is it just a bad ground or something?
Old Nov 28, 2007 | 01:38 AM
xoolander's Avatar
Re: Headlights and interior lights dim in an out
I am having pretty much the same problem
when I use my headlights, my dash, headlights and interior light with light on or door open will kinda of gently strobe, or dim and brighten as the engine idles.
It seems I am getting proper voltage.
Heeeeeeeeelp
Old Nov 28, 2007 | 07:07 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
If the dimming is erratic/ irregular then it could be fusible link A or its connection to the starter, or the C100 firewall contact.
If the dimming has a regular frequency to it and only at idle then it's just the regulator in the generator being slightly unstable. Nothing to worry about, but if anything external causes it then it has to be a bad alternator ground or some bad connection to the sense/ input wires.
Here are power distribution and charging system diagrams for '84 T/A's.
Attached Thumbnails Headlights and interior lights dim in an out-power-distribution-1.jpg   Headlights and interior lights dim in an out-power-distribution-2.jpg   Headlights and interior lights dim in an out-charging-system.jpg
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
