700 r4 question
Old Aug 21, 2003 | 05:49 PM
83t-top's Avatar
700 r4 question
I just completed a 383 swap in my 83 trans am. it is non emmissions with a 700r4 trans. my question is if the computor isnt controlling the engine, will the trans shift correctly or is there something extra i need to buy? also , what painless kit would be correct for my car? all i know now is it has to be a 18 curcuit because of the electric doors. any help would be appreciated.
Old Aug 21, 2003 | 07:51 PM
armac's Avatar
Car: 83 ta
700r4 has a ECM controlled OD nice to have for highway driving the rest is controlled by the t.v, cable
83 TA
81 DeLorean
68 AMX
Old Aug 21, 2003 | 09:55 PM
Morley's Avatar
The only thing controlled by the computer on a TH700R4 tranny is the torque converter lock up function. If you have a non-locking converter, don't worry about it, if you do have a locking converter, B&M makes a kit to use lockup on non CC engines.
Old Aug 23, 2003 | 08:22 AM
83t-top's Avatar
thanks for the info guys! im kinda new to the overdrive tranny so what does the lock up and non lock up function do? which one is best? thanks again.
Old Aug 23, 2003 | 02:34 PM
Morley's Avatar
On a non locking converter you'd disable the TCC, what lock up does is give you better gas mileage by locking the converter out, less drag on the engine that way.
Old Aug 23, 2003 | 04:51 PM
BADBIRD009's Avatar
or you can get a non lockup converter and modify the pump. this is what i did. i got my converter through torco. they sent me a new valve and screw to modify the pump, it even came with directions and was free with my converter. best part was it was only 320 bucks shipped for a custom bulit stall. that b&m box is like 130 i believe.
Vintageracer
Jan 10, 2020 05:33 PM
84 TA NV
Sep 6, 2015 08:02 PM
tonys91rs
Sep 2, 2015 07:07 PM
Mickeyruder
Sep 2, 2015 02:45 PM
