Fan Switch Wire
Old Oct 5, 2003 | 04:05 PM
RSGirl's Avatar
Fan Switch Wire
My fan in my car died so I bought a fan switch to replace it. I have located where the part is but am unsure of how to disconnect the wire from the fan switch sending unit. Any ideas? Thanks.
Old Oct 5, 2003 | 04:13 PM
mikes92rs305's Avatar
cut and splice it?
Old Oct 5, 2003 | 08:26 PM
onebinky's Avatar
If you are talking about the one on the driver's head, you slide it to the left or right, depending on which way the wire is facing. If you try to pull it straight out you will crack the plug. If you are talking about the water temp switch on the passenger side block, you just squeeze the plug and pull.
BTW, it's great to see a girl working on her own car. We don't see that to much around here
Matt
Old Oct 6, 2003 | 02:41 PM
RSGirl's Avatar
fan switch wire
Thanks. I found the wire. It was the one on the head. It came right out when I tried it.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
