how to wire up heater box
Old Oct 21, 2003 | 11:00 PM
CamaroEFI's Avatar
i completly took out my a/c in my 91 but i left all the wires in there. well, its starting to get kinda cold so i need a heater. i put in a box from an 84 but the connections are different. my question is how do i wire it up?
Old Oct 22, 2003 | 09:05 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
id go get parts from a 91 or your likely never to get it right
Old Oct 23, 2003 | 12:23 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I assume that you left all the wiring on your car intact ?? If so I can't understand why the plugs don't match up ??? The power for the system comes from a plug wired into the engine harness. The other connector runs thru the firewall to the heater switch & to the blower & relay on the other end. Where does the "new" connector come into play ??
In Any case; on the engine side of the fire wall there are just 2 wires that you need to worry about,....... Red and black. Red will supply the heater relay with power and black will provide a path to ground.
Connect ( or splice ) the red wire that's all by itself on the heater harness.
Then connect ( or splice ) the black wire from one connector to the other.
The Green and Blue wires on the heater harness are used for the AC system and are not needed if you are simply trying to get the blower to run.
I've had to overcome the same type of problem on 2 occasions,........ but both times it was due to an engine swap. As a result of the changed engine harness, the heater plug was different.
Hope that helps !!!
Old Oct 23, 2003 | 01:15 AM
CamaroEFI's Avatar
i'll try that in the morning..thanks
1992 Trans Am
May 10, 2023 07:19 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Casey Meyers
Mar 2, 2016 10:46 AM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
