Free Porn
Old Oct 30, 2003 | 02:12 PM
Jymn's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 1986 Camaro 350 MultiPort Fuel Injection
Transmission: 5-speed
Free ****
Ok, I'm sorry guys, but there really is no free ****. I just needed a lot of you to look at this because I really need help. So here's the deal:
I have a 88 Firebird Formula with a 5-speed that came stock with a 305 TBI and an open differential with drum brakes. I recently purchased an 86 iroc with a 350 MPFI and a posi rear with disc brakes, which I plan on swapping into my firebird. However, I was wondering if you guys knew if I could just swap the computer from the Camaro into my bird without running all new wires to my power doors and dome light and basically everything behind the firewall. I was hoping that I could just swap computers and run the engine wiring harness off of the camaro through the engine. So basically, use the camaro's computer and engine wiring harness to run all the sensors and whatnot through my engine, but keep the stock firebird body wiring harness's untouched. Or, do I have to swap everysingle wire from the camaro into the bird....? Thanks for your help, and sorry again for the syk.
Old Oct 30, 2003 | 06:20 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
what no pic's
i have no idea but had to post that was funny
Old Oct 30, 2003 | 06:58 PM
mlrsone's Avatar
where are you at and what are you going to do with the iroc body?
Old Oct 30, 2003 | 07:18 PM
Steve2000's Avatar
Car: 1988 convertible camaro
Engine: 5.0 TPI
Transmission: 5 speed
You can leave all of the wiring behind the firewall the same but you are going to have some wires that don't match up on the connector going through the firewall so you might have to play with those wires to get everything (wipers, etc.) to work.
Old Nov 1, 2003 | 02:25 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
LMAO, and i thought i heard it all, free **** lmao, next time just state the topic, cause with that u have a better chance of this gettin locked, most people here at thirdgen are really good at helping, so u dont have to state a dif. topic just so more people will look at it
Old Nov 1, 2003 | 08:14 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
you *******
well ok, the engine harness & ecm are on their own so what you have to do is drop the motor and harness. The easiest thing to do would be drop the engine kmember and swap the whole engine tranny to the other car. ALSO you WILL need to put the TPI fuel pump in your car that the 350's going in, the 9 psi TBI pump won't cut it.... also while your at it you should install new fuel lines...... pitfa
Old Nov 2, 2003 | 03:44 PM
Jymn's Avatar
Haha, I'm sorry guys, I know you guys are the best, I just really needed a lot of people to respond because I really want this project to be moving on. I live in MA right near Boston in the burbs. And Ok, so I have an 88 firebird with an open differential and drums in the rear, a 305 TBI with a 5-speed. I just bought an 86 iroc-z z28 with a 350 MPFI, automatic 700-r4 tranny and posi with discs. I'm swapping everything from the camaro into my bird, except the automatic tranny which im selling to my cousins friend. I'm swapping the brakes, brake booster, engine, rearend etc. I was only worried about swapping the computers because I wasnt sure if they would match up or what, because I havent done a computer swap before. So basically I take out the computer and the engine harness and it should transfer over to everything behind my birds firewall?? Is there any problems I should encounter or look out for? Also, any tips on making a computer swap any easier would be awesome. Thanks guys, and sorry again for the porno tease.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
TexasFormula
Sep 30, 2015 06:36 PM
FueledSoul
Sep 26, 2015 12:00 PM
