another instrument panel questions???
Old Oct 31, 2003 | 02:04 AM
MrStein's Avatar
Car: 87 firebird
Ok, the lights in my instrument panel are not working. I have 87 firebird thats mostly stock at the moment. I have already tested the tail fuse and thats good. Till lights work so that rules that out. On the printed circuit of the panel do all of the bulb holders need to be in place? Are they easily obtainable from a autoparts store? Would missing one create an open in the circuit? do the bulbs need to be in it, I currently only have 13 out of 16 in it. Can the speedo and the tach be reversed? the speedo being on the left and the tach on the right. Will they work if they are reversed. I just wanted to ask a second opinion or two.
Old Oct 31, 2003 | 11:54 AM
Morley's Avatar
Re: another instrument panel questions???
No, they have more than 1 source for power and ground
Yes, most should have them, but they would be "free" at a junkyard (pocketable item)
No and no
No they will not work, the printed circuit is made for one configuration of instruments and they don't wire up to the panel the same. If you look on the back there are screws that hold them to the panel and also provide electrical contact for the instrument. The screws are not in the same configuration for the tach and speedo.
Old Oct 31, 2003 | 05:02 PM
MrStein's Avatar
Car: 87 firebird
Well, thanks for your reply. After work today I found what i needed and still no luck. Guess i will have to just start tracing the board.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
redmaroz
Aug 16, 2015 11:40 PM
