Temperture Gauge replacement
Old Nov 3, 2003 | 06:34 PM
lighthorseozzy1's Avatar
I have a 1986 Firebird..What would be the procedure in removing old gauge and installing new gauge..Nothing hard to answer, i hope.This all i ask!!!!!!!!!:hail: :hail:
Old Nov 13, 2003 | 01:20 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
whats wrong with the guage? reason i'm asking is they don't go bad for no reason. there is a sensor that runs that guage and if your guage is wrong then its more than likely going to be that instead of the guage.
Old Nov 13, 2003 | 09:34 PM
3gc's Avatar
3gc
Car: Z28
I agree with tstokka. I would replace the sending unit first, or rather check it. I know on my car it's on the drivers side head between the 1 and 3 cylinders, yours should be the same.
Old Nov 13, 2003 | 09:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The first sign of the gauge being at fault/broken is, it doesn't do a 'test sweep' to full hot while cranking the engine. When you start (crank) the car, the gauge grounds and should go full hot then return to whatever temp the sender is reading.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
ChevyZ71
Aug 13, 2015 07:30 AM
