can you convert from 3wire 02 sensor to a 1 wire 02 sensor?
Old Nov 21, 2003 | 03:17 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
its an 88 nissan with 200k miles on it.(4give me moderators:hail: )but i dont want to dump a 100$ sensor in my 1000$ winter truck.
the truck now has a 3wire ..12v,ground, and the millivolt signal wire. can i install a GTA one wire 16$ 02 sensor in the exhaust and use the one wire? if i did not use the 12volt and ground will the computer still read the millivolt signal from the gm sensor and adjust fuel accordingly? sorry about the non 3rd gen question but i need my $$$ for my GTA
thanks
Old Nov 22, 2003 | 06:53 AM
Morley's Avatar
Should work, BUT the heated sensor was put there for a reason, probably because they were having problems keeping the sensor hot enough and if you use the truck in the winter you'll just compound that problem.
Old Nov 22, 2003 | 02:33 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
should ANY heated sensor work? if so were do i get a CHEAP one?
thanks
Old Nov 22, 2003 | 09:43 PM
Morley's Avatar
thanks
Pretty sure they all run $50+
Old Nov 23, 2003 | 06:43 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Heated sensors usually are pretty pricey. They are becoming more popular because they will react faster, they don't need the exhaust gas to be 500 degrees before it starts to read. It basically will bring the engine into closed loop faster than a non heated one. Depending on the ECU and it's programming you may run into a situation where you will get a check engine light if you convert. And if that happens, the ECU will default and go to a preset fuel delivery which will affect gas mileage as well as driveability.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
