TBI to TPI swap, speedometer not working...
Old Feb 8, 2004 | 08:59 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, all my other gauges work, except the speedometer. I removed the buffer box that the TBI ECM needed, but now I need to know which wire(s) I need to hook up on the gauge harness from the wires that were going to my buffer box. Thanks!
Old Feb 10, 2004 | 11:57 AM
Scott_92RS's Avatar
Car: 1992 RS
Nobody knows? Does anyone have a dash wiring diagram for a 92?
Old Feb 10, 2004 | 04:13 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You need to connect pin B11 of the ECM to the cluster VSS input & pin C1 of the ECM to the cruise control VSS input. The schematic is attached.
Attached Thumbnails TBI to TPI swap, speedometer not working...-ecmvin8f1small.jpg
Old Feb 10, 2004 | 04:17 PM
Scott_92RS's Avatar
Car: 1992 RS
SWEET! Thanks for the info!
Old Mar 31, 2010 | 08:27 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TBI to TPI swap, speedometer not working...
Question, my car was also converted from TBI to TPI. Originally a 91 TBI 5.0 and now it has a 90 TPI SD. My speedometer doesnt work either. Never did.LOL Where should i start looking? Should i connect a wire from a certain vss pin on my ecm directly to the vss itself? Is that what you are saying? Explain. I really want to get this thing working! thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
