Blinker staying on
Old Feb 19, 2004 | 03:22 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Blinker staying on
My passenger side blinker light comes on when I put my headlights on. It doesn't flash, just stays as a steady light. It does blink when I move the turn signal lever though. Could this be something with the bulb, or is it something else?
Old Feb 19, 2004 | 03:27 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Sounds like a bad bulb.
Old Feb 19, 2004 | 03:49 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's one of two problems.
One is a bad ground connection on the right-side cluster plug-in.
But it's more likely that one of the lines on the circuit board on the back of the cluster has a break in it, causing the cluster illumintaion lights to 'ground out' through the pass turn siganl indicator. You'll have to remove the cluster and check all the lines, especially those around the dash lights and find a way to jump the break.
Here's how I repaired the cluster from my 84Z. The circled areas show where the breaks were...
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
bigjay89gta
Oct 15, 2015 08:04 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
